Hello, I’m wondering if I could have some advice. I’ve got myself into a quandary, and I hope you’ll be able to tell me I’m just being silly!
I’ve got a good friend who has just offered me his current system - a Marantz PM7005 and KEF LS50 - for the princely sum of £800! (He’s just moved house, and as a result now has the space to upgrade his hifi system. He’s jumping in feet-first, and moving up to a pair of Monitor Audio PL300s, a Unison Research S6 amp and Chord Hugo DAC.)
I keep pinching myself to make sure I’m not dreaming! But I also thought I’d do some due diligence and read some reviews…
What I’ve read suggests that the combination should work fine (I think the amp has enough power? Opinions seem to differ), but lots of people suggest that the LS50s are very picky when it comes to positioning. My friend has had them on stands well away from walls, but my options are a lot more limited:
- They’ll have to sit on a piece of furniture (Skovby #87).
- They’ll also be fairly close to a rear wall – the back of the speaker will be about 20cm from the wall.
- One of them will also have a wall about 20cm to the side, but the wall won’t go any further than the front of the speaker, if that makes sense? The furniture is sitting with one end against a deep chimney breast.
So, my current thinking is that even with the limitations I’d be crazy to turn down the offer – am I right?!?
For some context, I’m “upgrading” from no hifi at all, so it’s certain to be an improvement from my TV speakers. I’d also be happy to look into some kind of isolation for the speakers – maybe some kind of rubber pad/feet?
All thoughts welcome.
