KEF iQ5SE
hi,i own a pair of kef iq5se's,recently discovered someone has poked/dented the centre part of the main speaker!! wasnt happy at all! is there anything i can do to rectify this or shall i just leave it and keep the grills on?
You can try and use some very sticky tpe to try and pull it back out, but the KEF ones are smaller than normal, so it's harder to do. You'll need to pop it along to your dealer and get them to replace the HF unit (solder job). This will more than likely be chargeable as poking drivers isn't an under warranty issue
