Covenanter said:
When people tell me "Shielded cables using a metal foil which shunt electromagnetic energy to the ground." I have a hissy fit and like Goering I reach for my Browning.
Chris
This is the passage I lifted it from:
"RF and interference signals can be reduced by adding screening or shielding the
complete cable. A cable shield may be composed of braided strands of a metal such
as copper or a non-braided spiral winding of copper tape, or a layer of conducting
polymer; a metal foil which is bonded to a plastic film. This is the type of shielding
used for Atlas EOS power cables and the shield acts as a Faraday cage so that any
electrical signals on the outside of the cage will not be present on the inside of the
cage. The shield works by shunting electromagnetic energy (the RF or interference
signal) to the ground. To do this effectively a shield needs to cover the conductors
completely, so that RF energy cannot readily pass through any holes in the shield; it
must have good conductivity so that energy can be easily conducted to the ground;
and naturally there must be a good connection to the ground at the end of the cable."
If you think it's b*ll*x, give John Carrick a ring and I'm sure will be happy to explain further.
