As a first foray into surround sound, I'm looking to put the speakers together on the cheap with a bit of investment in the receiver with a view to upgrading the speakers at a later date.
Caveated with the 'I'm completely new to all of this'...I've looked at matching some existing JPW speakers I have with whatever I can find second hand (so...ebay then). The fronts, rears and centre are easy to source but I'm not sure what to do about a sub.
Bearing in mind the general advice given about keeping speakers all 'in the family', I have seen a JPW sub, but it is passive and I _guess_ I need an active sub?
That said....I haven't yet purchased a receiver and I may buy this item new, say the Onkyo 606 or the new Sony 820 (once back on the market). My understanding is that these receivers will connect only to an active sub.
So, a couple of questions....are there receivers around that can feed a passive sub? Or does madness this way lie and I should only look at active subs?
If I do need an active sub, I haven't seen a JPW model so would need something else, is there a well regarded active sub that would blend well with most systems?
So, in summary:
1 - Can I use a passive sub,?
2- What receivers will drive a passive sub, or how would I otherwise provide amplification to it?
3- Please recommend a budget sub that isn't too picky about what it's matched with!
Rogue
So, in summary:
Rogue
