I notice that the mag has a Jargon Buster in the back. This is very convenient....but only provides definitions of words I can find on the web The jargon I have most trouble penetrating is descriptors used for sound. I think I understande but am not sure. I was going to go into a protracted narrative about this....but I think I'll spare you that. Instead, I will add a table of a selection of terms to get things going, provide context (from the mag) and offer forum members/staff the opportunity to provide the definition. I will maintain the OP to include the definitions as they are supplied. Moreover, if posters would like to suggest other terms (complete with context from the mag), I will maintain the table. Alternatively, if I'm the only one who finds this difficult, I'll let this thread die. Note: please do not use one term to define another. TermContext Definition Airy....this NAD is quite as airy and clear as the best....(July2008 p25) BrightThe top end isn't bright....(July2008 p14) Cohesion...the bigger 683 were criticised for a slight lack of overall conhesion....(July2008 p12) Detail....serve up a good dose of detail...(July2008 p14) InsightInsight is particularly good, vocals are natural and clear....(July2008 p19) Transparent....Vocal clarity increased and became more transparent....(July2008 p12)
