yes it's me again
Tried my sub again and used it for a while with the bass port covered, the extra bass extention is nice
I just want the extra bass comming from my front speakers
I can have many active studio monitors Mackie Mr824,adam T7v or T8v, yamaha hs7 all of them are not expensive,have deep bass and can play louder than most hifi speakers like dali oberon 3 or my speakers
if your budget is low and you want new "passive" speakers, i can only think of one pair of speakers
Monitor audio Bronze 100, 8" woofer, 110 db 52 hz free space in room 37hz -6db
Under 400 euros for a pair
Why hasn't other brands made something similar, speakers with power,bass without costing a furtune, studio monitors, yes theres a much bigger selection but they are active, i have an amplifer i would like to use
For more power, higher sensitivity or bigger speaker with just about the same sensitivity as my current speakers but higher power handle so it sounds cleaner when playing loud (higher limit) and to get speakers that can handle more bass when listning either to edm or loud or even both ?
Im kind of going for the last, since higher sensitivity (if you don't like klipsch) often is pa speakers, with 60 hz being lowest rated bass extention for the best pa speakers at a low price but then it's like 99% of all pa speakers is with a 10-12 or 15" woofer, which is to big for my desk and a desk in general
What is the point of having higher sensitivity if the speaker can't play deep bass and you want bass from the front speakers not a subwoofer you have to struggle to integrated perfectly (with no high pass filter for the fronts) ?
How good is the Ma bronze 100 for nearfield,bass and high spl ?
Any alternative ?
Any alternative ?
