- Aug 10, 2019
- 2,556
- 5
- 0
Hello
Having bought the Marantz CR603 I've had nothing but issues with AirPlay (as in streaming music from iTunes on my PC to the Marantz); however it works fine from my iPod function on my iPhone 4 etc... AirPlay does not show up on my iTunes screen on my PC (iTunes is fully up to date as is my iPhone and the Marantz system)
I downloaded the AirPlay upgrade as per the instructions and it went all fine; I'm able to stream internet radio and music from WMP on my PC (via the 'music serve' function on the Marantz) but I'm unable to get AirPlay to work...
Now I spoke to Jonathan Weston at Marantz AirPlay yesterday and he talked me through it all and how to hard reset the system and I did just that but still the same
However, I switched on my Pc this morning as I do every day for work; connected my iPhone and it synced as normal and then all of a sudden the AirPlay symbol appeared at the bottom right of iTunes where it's supposed to be. This is the first and last time it appeared as when I unplugged my iPhone as I needed to make a call, and then plugged it back in, the AirPlay symbol disappeared
Has anyone else had this issue; if so, any suggestions?
Regards
Regards
