- Aug 10, 2019
- 2,556
- 5
- 0
Many of you will read the title and think I'm nuts or at least a strange cook! But for those in the know and who have heard of this new product I would welcome some feedback to confirm whether it does indeed have magical isolation properties.
I have an oldish Soundstayle metal rack with glass shelves which is singing a bit now I have had to locate my mighty Spendor SP120R's relatively close to it. I'm sure it is impacting the performance of my Plinius CD101 which although sounding fantastic, may not be quite as precise/detailed as I remember it in audition. I intend to put one black ravioli pad under each foot initially to see if that does the trick. Apparently stage two is to stack two ravioli under each corner so that the original feet do not touch the shelf! The second option starts getting expensive because I want to "isloate" my Plinius 9200 amp aswell and each pad is GBP20.
If you believe the reviews, I will be flabberghasted how great an improvement these things bring. They even suggest putting a pad between the CD input cables to reduce air bourne vibration makes a big difference too!
I'm tempted to invest in a few but would welcome any thoughts
My kit is: Plinius CD101, Plinius 9200 amp, Spendor SP120R, Chord Epic Twin Speaker cable, Chord Anthem II XLR inteconnects, Russ Andrews Ultrapurifier block and Reference Mains cables
I don't work for an audio company
