Sell the cable too... 😂 then you’ll have more to spend on a CD player
Or coax out of CD11 into the streamer's DAC?Have you thought about trying a Cambridge Transport and feed it into the streamer?
No, I don’t think it’s a waste, if you are happy with it, then that’s all that matters.
If your picture shows how you listened to them then I suggest to try siting the CD players further away. I don’t think putting the new model on top of a BIG transformer in your amp will help the sound at all. Worth a try.
Agreed. Plus it won’t help your amp to stay cool… There’s a reason people buy hifi racks 🙂If your picture shows how you listened to them then I suggest to try siting the CD players further away. I don’t think putting the new model on top of a BIG transformer in your amp will help the sound at all. Worth a try.
Could this be a case of the amp needing a while to 'burn in'? I am relatively new to this, so I am not sue whether this is actually a 'thing' but there are certainly people who consider it to be so....
The other matter of course is that we cannot beat nature, and as we age, our hearing facility becomes impaired. That is some of us may not be as sensitive to the higher and lower frequencies that we could once hear, in our youth. This may be a factor in not picking up the brightness that you like - or a combination of both factors. Of course this could not be the case if you could hear the brightness you seek in your old model immediately before replacing it. And if that is the case, I am not sure I can help at all....
Even side by side would be better…..🙂Haahahah... You are right... This is not the definitive position, I place them like this just to test them... But I never thought that placing the cd player above the amplifier would make any difference in the sound...
From knowledge and experience……🙄[
It doesn't matter at all. Where do you people get these weird ideas from?
Exactly what I was going to say. Many items sited on an amp will hum or buzz annoyingly, and might limit the heat dissipation too.From knowledge and experience……🙄
Stacking components one on top of another is a noob error………🙄No mention has been made of noises, heat or anything else, but obviously a hot amplifier should be put on top.
Clearly not, as they are designed for it and I'm not a noob.Stacking components one on top of another is a noob error………🙄
They are not ‘designed for it’….🙄Clearly not, as they are designed for it and I'm not a noob.
