is it worth sacrificing a smaller screen size for THX ? Pana 46 inch G15 or 42V10
staggerlee
41
I had decided on a 46 inch screen Panasonic G15 tv but am wondering whether the Panasonic 42V10 with its THX accreditation is better I can't stretch to a 50 inch ( sitting distance 2.5m) So the question is , is it worth sacrificing a smaller screen size for THX ? what do you think ?
Well only you can decide why not try and see them side by side.
I have a 42V10 and use THX for blu-ray.
As the THX mode has overscan settings disabled, any other source other than blu-ray can show edge of picture artifacts.
I opted for the 42V10 over the 42G10 because of the THX.
As to whether the 46" v 42" is an issue only you can decide?
