There should be no difference if useing dedicated CD or Blue ray if connected by digital port, as it is then only a transport. All the difference comes from analogue outputs only.
javelin said:There should be no difference if using dedicated CD or Blue ray if connected by digital port, as it is then only a transport. All the difference comes from analogue outputs only.
the record spot said:the differences aren't as great as the "night and days", "wiped the floors" suggest.
dannycanham said:Well what have you got in a player:
The transport:
In a CD player it'll be dedicated to spin quietly and optimised for CD spin speeds.
Another type of player may not be (definitely aren't alot of the time).
The lense:
CD player lenses are designed specifically to track and focused to read CDs.
Other lenses aren't.
Dedicated keep it simple and seperate transport/dac/pre/power all the way to try to do the difficult task of keeping the emotional subtlety in the music.
