Do you listen elxclusivley to D&B ect? If so you may be better served aiming towards a speaker with that in mind. The speakers you list are all able performers but I think you might be better off going for a bedroom DJ type.
The speakers you list are up to about £350 on a quick google, given you need an amp too what can we assume you total budget it? I ask as I briefly owned a pair of KRK Rokit 10-3 active speakers which while perhaps not the best choice for many genres they are great party speakers.
They're pretty bulky but are three way with 10" bass drivers and can be had for about £800, all you'd need other than a source would be something like an inline attenuator for volume and you're good to go. I wouldn't recommend them for everyone but they could just be up your street. Although your room isn't huge with a bit of soft furnishing Ithink they'd get opn fine, I had mine in a fairly small room without major issue.
