That may be so, but listening to (and getting pleasure from) music isn't. IMO. Enjoying your hifi is more important than understanding it....though having some understanding greatly helps.andyjm said:?
Hifi is a technical discipline. To understand it properly, you need to have an understanding of the underlying equipment and theory.
CnoEvil said:That may be so, but listening to (and getting pleasure from) music isn't. IMO. Enjoying your hifi is more important than understanding it....though having some understanding greatly helps.andyjm said:Hifi is a technical discipline. To understand it properly, you need to have an understanding of the underlying equipment and theory.
This forum is (mostly) split into those who make measurements and how stuff works, a priority and those who concentrate simply on how stuff sounds and whether they like it. The former helps to explain the latter, but isn't obligatory when choosing a system that sounds subjectively pleasing.
lindsayt said:Covenanter, at what percentage level is 2nd harmonic distortion detectable to your ears?
Which SET amplifiers produce more than that level at sub-clipping power levels?
I put it to you that any decent SET amplifier used at appropriate power levels will be producing levels of harmonic distortion that are not detectable by your ears. And therefore for you or anyone else to criticise SET amps on the basis of something that no one can hear is akin to someone criticising the frequency response of speakers because they are 6 dbs down at 100khz.
If the distortion is inaudible then it doesn't matter if it is there or not in a hi-fi system.
I also put it to you, that based on your last post, you don't really know and fully understand the science behind harmonic distortion. Which is not really a criticism as very few people do. There are lots of technical aspects of hi-fi that I don't know or fully understand. In the absence of this knowledge I'm happy to carry on using my ears to decide what hi-fi components I want to use and keep.
	CnoEvil said:My advice, for what it's worth, is to park your technical knowledge at the door when listening to a system. Then concentrate on how the music sounds by asking subjective questions like: - Is it believable? - How authentic does it sound? - Am I emotionally drawn into the music? - Does it have immediacy, refinement, realism and authority. - Is the intention of the musicians being communicated?
If the answer to these questions is "Yes", then that's all that matters.
Given your love and knowledge of Classical music, I know that you understand what I'm trying to get at.
Do you mean close to the recording, or close to the performance that was recorded?Covenanter said:I listen to the fidelity to the original (or an original version that I have heard). If that is close the other things will follow.
Chris
At what frequency?matt49 said:lindsayt said:Covenanter, at what percentage level is 2nd harmonic distortion detectable to your ears?
0.6%
CnoEvil said:Do you mean close to the recording, or close to the performance that was recorded?Covenanter said:I listen to the fidelity to the original (or an original version that I have heard). If that is close the other things will follow.
Chris
If it's the former, you have no idea as to how it was intended to sound.
FWIW. I have heard a lot of expensive "neutral" equipment that sounded sterile and uninvolving.
I think that when push comes to shove, you choose a system the same way that I do ie. Play music that you know well, and if it sounds right to you, then you buy it.
I don't think R700s are strictly neutral, but they are engaging....but what is neutral, New Kef Refs, Old Kef Refs, Focal Utopias, PMCs, ATCs? They all sound different and they are all considered fairly neutral and accurate.
lindsayt said:At what frequency?matt49 said:lindsayt said:Covenanter, at what percentage level is 2nd harmonic distortion detectable to your ears?
0.6%
So we basically agree....which is good (realistic is a subjective judgement and a very valid one, in my book).Covenanter said:I can't be there at every recording of course. But I will have heard at least one performance of most things I buy so I know roughly what it should sound like. I've also heard live a lot of the performers I buy recordings of so I know what they sound like. I go on that. That's an advantage of classical over "pop".?
I don't think I used the word "neutral". I don't think any speaker is "neutral". In fact I think it's impossible to make a neutral speaker. I bought the R700s because they made recordings, particularly voice recordings, sound realistic.
Chris
CnoEvil said:So we basically agree....which is good (realistic is a subjective judgement and a very valid one, in my book).Covenanter said:I can't be there at every recording of course. But I will have heard at least one performance of most things I buy so I know roughly what it should sound like. I've also heard live a lot of the performers I buy recordings of so I know what they sound like. I go on that. That's an advantage of classical over "pop".
Chris
By using the word "neutral", I'm simply referring to equipment that is supposed to be as true to the recording as possible....it's the Holy Grail for some.
