So I've come to a conclusion on what I believe to be the case on bi-wiring vs single wiring in terms of sound (I'm an atheist). But what about the effect that biwiring has on impedance and the response of the amp?
Presumably if you separate the high and low frequency sides of the crossover, you get a higher impedance on each so that in parallel they achieve 8 ohms (say). Does an amp with A and B speaker outputs just parallel them up so you're back to square one regarding driven load, or is the amp circuitry more clever so you can attach a pair of 4 ohm speakers without that becoming a 2 ohm load?
Ive just ordered some biwiring speaker cable because the outside diameter of 4x2.5mm sq is less than 2x4mm sq so easier to hide under the carpet but it got me thinking about whether using the A and B outputs of the amp would make it a higher driven load and hence potentially less likely to clip at high volumes.
As I say, I've bought the 4 core without expectations of it being better, but it just for me thinking about whether to use one set of terminals at each end or two.
