ThisIsJimmy
I'm going to start off with a statement that might get me shot here, but if you are looking for an AMP/DAC, as well as looking at the features you require, consider it's tested and measured performance. In that regard, the IfiZen Dac could be better. It's worth checking out ASR as a reference in this regard. However, I know right now if you live in the UK we don't currently get bang for our buck when looking internationally (thanks Brexit) so if anything strikes you as a potential investment, do check the shipping and customs import duties before you decide to buy if this is coming from abroad as it may put you off or become unaffordable.
As for the beyer lower ranges being 'bright'. The 770s are more bass heavy, so I wouldn't really call them bright. The 880 80 ohm and 250 ohm are bright in the trebble (the 80s suffer from sibilance too). The 880 600ohms dont suffer either of those issues, but require an earthquake to power them properly. Having not tested the 990s yet i cannot advise on them.
I'm currently experimenting with pad swapping, and I am finding it can completely change the characteristics of a set of headphones. If you have a set of cans you like, and you do your research, this could be an option if you want to switch up your current sound without buying a new pair.
