Thanks David I will order one to play all my SACDs on.Most eastern countries are fine - western is 110 volt. As long as the voltage is the same (should be able to Google different countries - ours is 220 volt) it’s fine. Some products may be dual voltage.
Thanks Bill just cancelled that then.Voltage is fine as it was standardised across mainland Europe ages ago.
You will need to change the mains plug as they are different in Germany. (If the lead plugs into the player you can change it for an English lead)
Specifications do vary between countries so check on the German website that it has all you want. (In particular make sure it can be changed to the English language (Most can)
Bill
You bought it just as I posted, however there may be a problem if the plug is built into the power brick (It has an external power supply) as it wont fit a UK socket, and will thus require an adaptor
Thanks Bill cancelled it. Cheers.You bought it just as I posted, however there may be a problem if the plug is built into the power brick (It has an external power supply) as it wont fit a UK socket, and will thus require an adaptor
Bill
Yep, I will just wait until the price comes down now. Cheers.There’s simple adaptors you can use to plug into mains, or just replace the mains cable as it’s only a figure of 8 mains socket on the power supply.
But why not just order one from the U.K.? It might be a tad more even in the sales, but at least it’s easier for you to send it back when you decide it’s not needed!
