Normal
MicrosoftInternetExplorer4
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-fareast-language:EN-US;}
p
{mso-margin-top-alt:auto;
margin-right:0cm;
mso-margin-bottom-alt:auto;
margin-left:0cm;
font-size:12.0pt;
mso-fareast-font-family:"Times New Roman";}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:36.0pt;
mso-footer-margin:36.0pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
Hello,
I have just bought an old acoustic energy aego p5 system but I’m not sure what is the best way to connect the audio to my Panasonic blu-ray player (dmp-bd35). The Aego p5 is quite an old system and it only supports audio via analogue rca or optical digital. I know the Panasonic can decode the hd audio channels but is it possible through this system? If not can some one tell me what is and what setting the bitstream/pcm should be set to on the Panasonic? Thanks
margin:0cm;
font-size:12.0pt;
p
margin-right:0cm;
margin-left:0cm;
font-size:12.0pt;
@page Section1
div.Section1
{page:Section1;}
font-size:10.0pt;
Hello,
