gbhsi1 said:I've moved the dino as far as possible from the turntable but can't get rid of the hum, I use shielded cable and a standard thin wire (shielded too) as the earth connection. how can I eliminate the interference totally? what could be causing it?
simon3102000 said:Projects do hum unfortunately, one of the big problems with them from what i have read.... Has yours got the upgrade kit installed? This is meant to take away the hum but ive yet to try it, only £25 for the kit from henley design.
gbhsi1 said:simon3102000 said:Projects do hum unfortunately, one of the big problems with them from what i have read.... Has yours got the upgrade kit installed? This is meant to take away the hum but ive yet to try it, only £25 for the kit from henley design.
upgrade kit? what's the upgrade?
Alears said:gbhsi1 said:simon3102000 said:Projects do hum unfortunately, one of the big problems with them from what i have read.... Has yours got the upgrade kit installed? This is meant to take away the hum but ive yet to try it, only £25 for the kit from henley design.
gbhsi1, I think he means:- The package includes: •2 Rubber Gromits and Screws •Rounded Drive Belt & Alternative Pulley See here:- http://www.henleydesigns.co.uk/product.asp?shop=0&ProductID=841
