Deleted member 2457
A guy has said on AV Forums that you access the service menu to tell. Is that possible? I don't have the manual as it was ex-display. Cheers for any help.
gel said:I don't have the manual as it was ex-display. Cheers for any help.
Yep, cheers Norman! I am going to have to do some searching or the remote when I get home, but I suspect its not possilbe unless you have a service.spiny norman said:gel said:I don't have the manual as it was ex-display. Cheers for any help.
Help like this, you mean?
Well, I am looking at it at the moment and I go into settings, then click on the product/service info and it just gives me the serial number and some other pointless info. Then says call LG if you have an issue on this number. I am waiting for another response on AV just to clarify.gel said:Yep, cheers Norman! I am going to have to do some searching or the remote when I get home, but I suspect its not possilbe unless you have a service.spiny norman said:gel said:I don't have the manual as it was ex-display. Cheers for any help.
