Hello, I have purchased new back dipoles and yesterday I was trying to re-balance the delay settings.
The doubt that I have is about the correct way to meassure the distance from the listening possition. My sofa is right against the wall where the speakers are placed. Each speaker is placed about 30 cm above each corner of the sofa. From the center of the sofa to each speaker there is a distance of 1,5 meter more or less. From my listening position (right corner) there is a distance of 30 cm (I can almost touch the speaker). I would like to define a reasonable setting that would work for any listening possition in the sofa.
What would be the right setting? 1,5 metter? Even thought the sofa is right agains the wall where the speakers are placed?
/sites/whathifi.com/files/images/Imagen0203.jpg
