- Aug 10, 2019
- 2,556
- 5
- 0
New to home cinema, just bought the Jamo A102HCS5 speaker package which I am trying to connect to a Denon AVR 1909, couple of questions:
1) How do you connect the sub to the amp? I have a single subwoofer cale but there are two left and right line in connections, do I need another cable?
2) There are adjustments on the sub, for level, cut off and phase, what should these be set to? Being new to this was hoping that the auto set up on the amp would take care of all this.
3) Does it matter where the sub is located within the room, due to the layout of the room the sub will have to be sited next to the rear speakers close to my viewing chair which is around 3 m from the tv and front & centre speakers. Will this have a big impact on the audio performance?
Help would be appreciated.
