how to bi wire my speakers?
markyboy156
203
hi i have the onkyo nr5008 amp and a 7.1 monitor audio silver rs6av speaker package the (older series speakers? i was told that you can bi wire the fronts centre and rears on this speaker package is this correct? and if so could i bi wire the front centre and rears to the onkyo nr5008 or could i only bi wire the front speakers need help asap please
Bi-amp the fronts and Bi-wire the center. Same as what i have in my signature. Its sounds very good!
Take the binding connecter off the speaker terminal and run 2lengths of wire from 1 output on amp. Connect 1 run to lower speaker connecter and other to the top one. Do same with others.
Remove the bridge on the back of your speakers, otherwise they will blow. Then connect two wires to the positive terminals. Twist the opposite ends together and plug into positive on AV. Do the same for Negative.
Done
I know the 5008's a monster of an amp, but can it bi-amp the front speakers while running in full 7.1 mode?
