Hello,
I have the below back connections on the Yamaha RN 803D. I wanted to record the sound from an old tape (from 1982) to computer. The DEC does not have amplifier and I was thinking to connected to Yamaha receiver.
I connected the DEC to Line 2 IN and from Line 2 REC I used an RCA to stereo jack to connect the Yamaha to computer Line IN. Then, I selected from the remote control (on Yamaha) the Line 2, so I could hear what I suppose to record.
The problem was that I did not have output sound on the stereo jack. I know that this is the old way of use the "tape in / out" of amplifiers in order to record the sound.
After consulting manual I found this specification:
In order to prevent the audio signal from looping when an audio recording device is connected, the audio signal is not output from the LINE 2 (OUT) jacks when LINE 2 is selected. Similarly, the audio signal is not output from the LINE 3 (OUT) jacks when LINE 3 is selected.
Doesn't this affirmation contradicts the below schematic, logic of useing Tape in/out, recording method? About what loop are they talking about?
After that I made a test: I selected as source on Yamaha the USB and then REC Out was connected to a NAD amplifier. I had sound as well on yamaha speaker and the same sound, at the same time, on the NAD amplifier. The volume knob on yamaha it wasn't influencing the REC / NAD volume, but only the volume on speakers connected to the yamaha.
Yamaha RN803D does not have a Pre Out connectors. Is it ok to use the Rec Out to connect it to another amplifier?
Thank you for your time!
