How can I find out my network password?
JoelSim:Nope. The default password for the Adminstrator login is nothing (ie just leave the current password box empty)
Kindest regards
For future reference (after this has all resolved itself).
Get an external backup HD.
Buy this backup software...
http://www.shirt-pocket.com/SuperDuper/SuperDuperDescription.html
Do a regular full, bootable backup.
After my iMac's HD needed to be replaced, the restore of the entire system (including all settings, passwords, emails, network settings.. the lot) was completed in 20 minutes back to an identical state to how it had been at the last backup. That 20 minutes was all spent having a cup of tea apart from a few mouse clicks to set the thing going.
I give up. John Lewis can damn well sort it out, they are the ones who have replaced my hard drive when there was nothing wrong with it which had all the details in. They can bloody well sort it out.
Thanks for all your help guys anyway.
a call to tech support tmw might be the best bet joel? i cant find any more info...
JoelSim:
maxflinn:a call to tech support tmw might be the best bet joel? i cant find any more info...
Thanks for trying mate
you're welcome
For speedtouch 585...
username - admin
password - admin
click on homenetwork
click on Wlan::[name of ur router]
click on configure
encryption type and network key should be shown on screen
Don't know if this is still relevant, but here's a link to freeware software that will show you the wep key on your computer. Only windows so no luck if you use a mac. link
Of course, there's a good reason why it's so difficult to find out the key....it stops someone else using your connection. Moreover, if someone "professional" has set up your router, they should have changed the admin password to prevent unwanted access.
Are you sure you don't have the router admin password or the WEP key? My Mum didn't know hers but after a bit of rummaging in the box, the key was written on a piece of paper. If you really can't find your key, I think your best bet is to do as someone else said and that is factory reset your router. The manufacturer provides this capability just in case you forget the password.
If you do go for a factory reset, it will also remove the configuration of your network too. So, it looks like you might have to invite JD round for dinner with an exclusive cheese board and carefully selected wines and get him to sort it while you relax and listen to some tunes.
Well I did have a very late-night exchange of mails with JS when he first wrote this thread, but I think he chickened out when I said "open a terminal window and type sudo rm -rf /"*
*HINT - don't try this at home
JoelSim:
JoelSim, pardon my ignorance but have you looked on the router for a little sticker which usually has the network password?
guys, this thread is about 3 weeks old, id say joel is sorted by now
