Hi All,
So this is the situation,
Room size... 8x15ft
I have a 2019 LG C9 55" TV wall mounted... external sources include, SKY Q 1TB box, Netflix & Amazon Prime Video...
I have a Rega Planar 1 Plus Turntable (Phono out only)
The TV is mounted about 7.5 ft away opposite the Sofa.
I plan on having a 3.1 system, Front left & right, centre and sub.
My idea is when using the receiver for stereo only the left & right + sub will be used.
When watching TV/Movies etc.. all speakers will be used as a "home cinema" if you like...
This is the equipment I am looking at purchasing..
Marantz NR1711 AV Receiver
Dali Oberon 5's as L/R speakers
Dali Oberon Vokal as centre
Dali E-12F as Sub
Any criticism of this setup? I have never done this before, have always just had a Sonos sound bar but im hoping this setup will be an improvement!
I just want to make sure these components are all of a similar standard, to ensure I am making the most of all of them and getting the best from my TV at the same time. Anyone spot a major weak link or a components which seems overkill for this setup?
Any advice welcome. Thanks,
Dan
Room size... 8x15ft
Dali E-12F as Sub
Dan
