ho hum...............
zappa 100
26
i have a persistent and annoying hum emanating from my alpha 9 power amp ,through the speakers. the volume of the hum stays the same regardless of volume control position. the mains block is plugged into a double socket . in the other side of the socket ,a small lamp is plugged in. when i either switch this lamp on or off at the socket ,the hum disappears, only to return about 1 and half to 2 minutes later. can anyone explain why this should happen and if it can shed any light on to the source of the hum?
Andrew Everard
1,878
Energy-saving lightbulb, by any chance? Or a low-voltage halogen lamp? They can be very noisy in electrical terms...
[quote user="Andrew Everard"]
[/quote]
Yes, but if it went after he turned it off surely this cannot be the problem. Perhaps try swapping round the plugs around, it may be a dodgey socket.
[quote user="JoelSim"]Why don't you try a shielded mains cable?[/quote]
A very viable point...
My mum's Quad 405 went the same way too...but it did take 28 years of use!
