- Sep 24, 2014
- 1
- 0
- 0
Hi, a question from a forum newbie here. I listen to mostly classical music on FLAC (downloaded) on the rather modest system that I'm just putting together. On many of the tracks, I'm somewhat bothered by the hissing sound that accompanies the music. The hissing sound is not constant, it accompanies the music in a different frequency from the music (the hiss seems to be mid-frequency). - Files: Hi-res FLAC- Playback software: Foobar with ASIO4all, on Windows7- Soundcard: Onboard Realtek soundcard- Output to Amp: SPDIF optical- Amp: PM6005 with built-in DAC (input directly from PC with SPDIF optical)- Speakers: KEF Q300 Could you please suggest how I could go about determining the source of the problem and what upgrades are necessary? From my research, it looks like some possible source of problems are below. Many thanks in advance! - Needs better playback software. Or Foobar is not configured properly- Needs proper soundcard instead of onboard- Needs to bypass soundcard entirely. i.e. Needs to output through USB -> USB to SPDIF converter -> input to PM6005 DAC- Either amp or speakers defective. But doesn't seem likely because some files sound fine
