shadders
andyjm said:shadders said:busb said:As has been pointed out, analogue does not & cannot have infinite resolution.
Can you explain why this is not the case ?. Thanks.
Regards,
Shadders.
All real world analogue systems have noise superimposed on the wanted signal. Suppose the wanted signal changes by a very small amount, but this small amount is less than the noise amplitude - it will be impossible to tell whether the signal has changed because of an intended change, or just because of noise. So the 'resolution' of an analogue system is a function of the noise inherent in the system. Hence why SNR (signal to noise ratio) has meaning for an analogue system but can also be derived from the resoultion of a digital system.
Thanks.
I understand that small signals will be lost in the noise - but they will still be processed by the amplifier. An amplifier may not be able to resolve the signal for you to hear, but it does still process the signal.
So, an amplifier can have infinite resolution, but obviously from a practical aspect, that resolution is impacted by system noise - not useable. Perhaps resolution is not the correct term for analogue electronics, and we should use S/N.
Regards,
Shadders.
