High freq of speaker spec more than 20.000 hz. Does it di any good?
dhias
I found some speaker which has reponse from 40-60.000 hz. Does that high frequency (60.000hz) do any good in sound? because human ear only hear max 20.000 hz?
Frank Harvey
567
Different schools of thought. There will be those that go by numbers and tell you that anything above is pointless and will make no difference whatsoever, then there will be those that talk about harmonics that are way above our hearing that will still have an effect on the frequencies we can hear.
chebby
1,257
34
19,220
Ignoring whether anyone can hear them; which sources are capable of presenting 20KHz - 60KHz musical signals to the amp and speakers?
If there is source equipment that can do this; are there any media for these sources (downloads, CDs, LPs, radio etc.) that can carry frequencies this high?
If the answer is 'no', then tweeters capable of 60KHz are just for technical 'bragging rights'.
CnoEvil
556
14
I asked something similar here: http://www.whathifi.com/forum/hi-fi/a-question-for-the-speaker-manufacturers-on-here
dhias
Thank you for the information. It's quite helpful
