Just found this on Youtube. In theory it sounds very interesting. Hope they pull it off.
https://www.youtube.com/watch?v=CYZtTdiltTg
Infiniteloop said:Just found this on Youtube. In theory it sounds very interesting. Hope they pull it off.
nopiano said:Maybe I'm not imaginative enough, but I'm more convinced that digital sources should be played that way - digitally.
Oldphrt said:It's pretty obvious that an extra process (cutting and replaying a vinyl disc) added to an audio signal can't improve the sound quality.
nopiano said:Absolutely, and though I've not bought any recent LPs to verify this, there are numerous reports that the master from which some new LPs are made is 'better' - e.g. less compressed - than the equivalent CD. Some despite the extra process, not because of it, the end result may be preferred.Oldphrt said:It's pretty obvious that an extra process (cutting and replaying a vinyl disc) added to an audio signal can't improve the sound quality.
Oldphrt said:That's also unlikely because CD requires less audio compression than vinyl. Not that compression is much of a guide to audio quality anyway.
MajorFubar said:Oldphrt said:That's also unlikely because CD requires less audio compression than vinyl. Not that compression is much of a guide to audio quality anyway.
It might require less but in these days of the never ending loudness war, it's not digital's inherrently huge dynamic range that's exploited, but its ability to tolerate dynamically-smashed brickwalled audio that a cartridge wouldn't track.
Absolutely, and though I've not bought any recent LPs to verify this, there are numerous reports that the master from which some new LPs are made is 'better' - e.g. less compressed - than the equivalent CD. So despite the extra process, not because of it, the end result may be preferred.Oldphrt said:It's pretty obvious that an extra process (cutting and replaying a vinyl disc) added to an audio signal can't improve the sound quality.
