Hi, just wondered if anyone has any advice on whether a rotel a14 would be a worthy upgrade from a Marantz pm6007…also considering a rega brio ? Looking to pair with q acoustics 3050i.
as pretty much the same pricewise I wouldn't consider this an upgrade, a sideways move with different dynamics perhaps but only you could determine whether it is an upgrade for you.Hi, just wondered if anyone has any advice on whether a rotel a14 would be a worthy upgrade from a Marantz pm6007…also considering a rega brio ? Looking to pair with q acoustics 3050i.
Hi appreciate the feedback..do you have any suggestions of which speakers would make a better upgrade and what pair well with the Marantz?as pretty much the same pricewise I wouldn't consider this an upgrade, a sideways move with different dynamics perhaps but only you could determine whether it is an upgrade for you.
What's lacking from the Marantz and why did you buy it in the first place?
I consider the best upgrades come from a change of source of speakers, perhaps you should be looking to upgrade your speakers rather than the amp.
Much will depend on your room size and budget but even more on your ears.Hi appreciate the feedback..do you have any suggestions of which speakers would make a better upgrade and what pair well with the Marantz?
Hi just been looking at some Dali’s what range would you suggest , my budget is around £350 second hand..was thinkim along the lives of the Oberon but not sure?I agree with the Dali suggestion. It’s what I have and very happy with them. The Marantz amp punches above its weight in my opinion.
Floorstanders I presume unless you already own speaker stands.....Hi just been looking at some Dali’s what range would you suggest , my budget is around £350 second hand..was thinkim along the lives of the Oberon but not sure?
