Help with Tannoy Revolution DC6 Crossovers
gareth-r
Hi I have a pair of Tannoy Revolution DC6 Expresso Speakers, im using these as front L/R in a 7.1 setup can anyone tell me what I should be setting the crossover frequency to on my Sony STR DN 1040.
Link for specs from Tannoy below.
Many Thanks
SpecificationsRevolution DC6PERFORMANCERecommended amplifier power (Watts RMS)20 – 150Continuous power handling (Watts Peak RMS)75Peak power handling (Watts)300Sensitivity (2.83 Volts @ 1m)88dBNominal Impedance (Ohms)8Frequency response (-6dB)46Hz – 35kHzDispersion (degrees conical)90DRIVE UNITSDual Concentric™ high frequency 25mm (1”) Titanium dome with Tulip WaveGuide™Dual Concentric™ low frequency 150mm (6”) treated paper pulp cone with rubber surround.44mm (1.75”) edge wound voice coil.CROSSOVERCrossover Frequency 1.8kHzCrossover Type Passive low loss 2nd order LF, 1st order HF
For larger 'mains' like yours, i believe 80Hz is a good starting point.
Less is more with subwoofers, so it's usually better to ensure their contribution isn't obvious. As soon as it is, then lower the level a shade.
Good luck!
gareth-r
Hi, im running a diy version of the bk Monolith if that helps, please note my tannoys are the smaller stand mount versions.
Sorry for delay but my post keep bouncing back as spam.
