Hello,
I am relatively new to vinyl and I am interested in creating a setup for my room. I have the following equipment picked out on a prospective wish list:
Rega RP3 Turntable w/ factory installed Elys 2 Cart, Cambridge Audio Azur 551P Phono Preamp, AudioEnginge 5+ Powered Speakers with stands.
I have done some research, but I would like the opinions of some fine people of this forum! This setup will most likely go on top of a bookshelf. My was initially $1500, but with the above equipment, I am at the $1600-$1700 range. I'm not completely heart-broken over that, but I was wondering if there were some options to get the cost down that would not be too much of a downgrade (I can push the budget slightly). My room is somewhat small, but I will be able to position the speakers in a pretty ideal location, for the sake of sounstage and bass response. I was also wondering if you have any suggestions about the way I have allocated funds for the setup. Do you think I should spend less on the turntable and more on the phono preamp or speakers? Or vice versa? Or some other combination? I will be listening to jazz records almost exclusively. Thank you very much for your time and I appreciate any suggestions!
Best regards
Best regards
