Help with Dip Switches
PaulX101
29
Hi what would you recommend setting the Dip switches when coupled to a Ortofon Quintet Red MC Cartridge,probably unnecessary but the deck is a Proj-ect Evo Classic, A Nad C700 Streamer,a pair of focal 906 speakers & BK P10 150 Gem Sub.
What makes it worse is that the manual also offers
Loading:
Dips 1&2 on = 1.1nF / 33 ohms
Dips 1&3 on= 1.1nF / 100 ohms
Dips 1&4 on= 1.1nF / 1K ohms
Loading:
Odd, because that's different to what it says on the base, or maybe not....
I would ignore switch 1
However, once you have Gain set correctly, you play with Loading and choose what seems best.
Ok thanks Al ears, I shall give your 1st suggestion a go, and see how that sounds, If not I will play around with it and see what happens
Loading:
Loosely speaking the ‘loading’ switches turned on to the right is what MC needs, while turned off to the left is for MM. [Your pic shows it set for a low output MM]
S1 represents the capacitance, while S2, 3, and 4 represent the impedance. The former is measured in fractions of a Farad; the latter in Ohms. (Nano is a billionth, hence a lot more than Pico which is a trillionth!)
As Al says, play around as you cannot harm anything. But turn the volume down when switching in case it generates a click or thump.
Ortofons seem to like low impedance, so I’d begin at Dips 1&2 on = 1.1nF / 33 ohms. And S3 for gain, unless that’s too quiet, when S2 will be louder.
Enjoy!
