HELP! which speaker cable?
Hi all, Ive just ordered my new home cinema from RS yamaha RX-V667 paired with kef2005.3 speakers. Ive purchased qed silver ann xt for centre speaker and cambrige audio ultra micro for the other 4 sat as im running under carpet. Not sure if the cambridge is a good choice or qed micro is better any suggestions would help and i have ixos xhd308 x2 optical leads for skyhd and a onkyo dock .Would rather have qed or other for around £60 for two 1m. Ideas please. Thanks very much peeps Daz
Hi Daz, ideally you want to use the same quality speaker cable for the centre, front left and front right speakers so these integrate well - these being the most important channels in a 5.1 setup. The cable used on the rear speakers matters less as these are for effects (so the Micro cable should be ok). I'd recommend putting Silver Anniversary XT on the front left and front right as well if you can.
