paradiziac
- Jan 8, 2011
- 17
- 0
- 0
CnoEvil said:IMO. Also isolation of components (ie. it's effectiveness) and quality of power supply.
Yep. Much more so with digital sources than amps, IME.
Would now be a good time to run? :shifty:paradiziac said:CnoEvil said:IMO. Also isolation of components (ie. it's effectiveness) and quality of power supply.
Overdose said:andyjm said:baldy38 said:Hi all,
If you are running a streamer into an external DAC (high-end) via a digital out, does it make any difference to the sound quality which streamer you use (assuming the same type of file is used)?
Because if it doesn't, why, if you have good DAC, would you buy anything other than a Squeezebox Touch? It would seem pointless to spend many times more than that if all the DAC is reading is a bitstream.
Forgive me if this is daft, but I'm only just dipping a toe in the streaming water at the moment.
Thanks for any advice you can give.
As Mr Coates rather long-windedly explains above, jitter at the point the digital signal is turned back into analogue (the D2A chip in the DAC) really matters.
It is how the DAC generates that clock that decides whether the streamer has any impact on the overall sound quality.
A DAC clock that is slaved to the clock in the streamer via the S/PDIF link will be very sensitive to streamer quality, a DAC that has a local clock and an asynchronous link to the streamer (async USB or wordclock output) won't be sensitive at all. Halfway in between are DACs with jitter mitigation circuitry - input filtering using multiple PLL steps, FIFO buffers and whatever else designers can think of.
So like much in life, the answer is not a simple yes or no - it depends on the topology of your system, and the design of the DAC.
At what level is jitter audible and how does that figure compare with the levels of measured jitter in AV products?
oldric_naubhoff said:I never was too much interested in streamers. But seeing they are consistently becoming the standard medium for digital music playback for the few years to come I am becoming more and more interested.
I was therefore recently wondering; where is the miracle of oversampling taking place? is it within the streamer or is it just before D2A conversion? do streamers just pass on the bits as they are received or do they manipulate with the source material.
this is very interesting to me as I'm a no fan of oversampling and I don't want my NOS DAC (if I finally have one) to decode information as it not really is at the source!
shooter said:The clock is important part but can be very expensive, some costing more than medium priced spinners.
CnoEvil said:shooter said:The clock is important part but can be very expensive, some costing more than medium priced spinners.
You're not wrong: http://www.kronosav.com/products#ecwid:mode=product&product=6443178
andyjm said:If you want really low jitter numbers, its no good having the clock in a separate box, the cabling, line drivers and receivers will introduce more jitter than the fancy clock will cure. The place to have the clock is on the circuit board next to the D2A chip itself.
The 'best' technical solution is either to have the D2A chip and a high quality clock in the streamer, or to have the D2A chip and high quality clock in a separate DAC box, but have an async protocol (USB, wordclock output) between the DAC box and streamer so that the DAC's clock is independent.
CnoEvil said:oldric_naubhoff said:I never was too much interested in streamers. But seeing they are consistently becoming the standard medium for digital music playback for the few years to come I am becoming more and more interested.
Hi Oldric, you may be right, but I think it's a mistake to rule out listening to something based on how you think it's implementation will effect the sound. Since Linn is the brand I'm familiar with (and prefer) here is some reading, in case it's of interest: http://forums.linn.co.uk/bb/showthread.php?tid=15456 (post No.2) http://docs.linn.co.uk/wiki/index.php/Products (check out the Technology section)
paradiziac said:With the dCS, the clock signal is sent to the DAC separately via a word clock output, that's not the same as a digital source embedding clock data in the SDPIF signal and sending it to a (jittery) SDPIF receiver chip in a DAC.
andyjm said:You would almost think they wanted to sell you another box.
CnoEvil said:andyjm said:You would almost think they wanted to sell you another box.
It's all academic, as I can't afford any of their other 3 boxes! :wall:
