- Aug 10, 2019
- 2,556
- 5
- 0
Hi All,
New forum member. Hope you can help / advise.
I have recently upgraded my entire AV setup from 28"CRT + Denon AVF100 to the new Pioneer BDP-LX71 and SC-LX81 amp along with a Sony KDL-40W4500.
Very impressed with the set-up. Picture quality from the BDP is fantastic. Cars, Wal-E, Transformers etc look and sound fantastic. However, a couple of issues that I need some help / advice with:
1.) The BDP is very slow at power-on. I don't mean loading a BD (which I expected to take some time), but when the power button is operated to turn the machine on. It takes upto 60 seconds before it can be operated. If I press any button, "Please Wait" is diaplayed for a second before "Power On" comes back. Is this normal? It has done this from day 1 (Firmware 1.17) and still does it (upgraded to Firmware 1.21).
2.) The SC-LX81 is fantastic. Sound quality is excellent, even in stereo from CDs. Minor issue with video upscaling though. When compared to the KDL's built in upscaling from Sky+ (on SCART), the LX81 is brilliant (most of the time). However, on a more frequent than I would like basis, horizontal lines appear across the display. Very difficult to describe. Not white or black or like that, but more like an interlacing issue. Not sure if it's the LX81 or the KDL. Anyone else seen this?
3.) Also the LX81 upscaling. If the signal has a large white area (TV 'flashback' sequence or similar), then the HDMI input appears to reset, causing the screen to go blank for a few seconds. Anyone else seen this? This only happens with the Sky signal, not the BDP signal. Doesn't happen through the SCART signal.
Not sure what to make of the second two issues, having neither had an LCD TV, HDMI or an upscaler before. Can anyone advise or help please.
Ian
Ian
