Help, please! Is it possible to... ?
6th.replicant
292
Can anyone please advise - I have an iMac, in my study, with iTunes containing ALAC files that I would like to stream to my DAC/hifi, which is in the sitting room. Is there a device that would enable me remote access/control the iMac from the sitting room in order to stream music to the hifi? (Does the iPad have such a function?) Ta [:)]
iPod Touch or iPhone.
You'll need the latest versions if you want your network to run in 802.11n mode, unless you've got a router that support n and g connections simultaneously.
6th.replicant
292
Fahnsen:iPod Touch or iPhone...
Thanks for response. I feared that might be the answer.
Really, really, really, really, really, really, really, really, really, really, really regretting signing up for an HTC Legend instead of an iPhone
There's always the possibility to control your computer with a remote control extender. There's all kinds, from cheap one-to-one wireless dinguses to advanced wired systems from Xantech, Speakercraft, Russound and others. You won't get a display though, so you'll have some difficulties with finding the right music...
http://androidandme.com/2010/04/reviews/remote-for-itunes-better-than-the-original/
In case links aren't tolerated here:
There seems to be a new third party Remote App for Android.
6th.replicant
292
Fahnsen:
Ooo, OK, excellent, I'll have a look...
Thanks for heads up, much appreciated
