I have just bought my first home cinema kit, AV, Yamaha z7,Speakers, m&k s150's & m&k ss150's , m&k mx350 sub.
The sub I bought secondhand,
The problem I have got is That I cannot get the sub to work, You can hear it a little when turning the power on and also when doing auto set up for the speakers with the mic.
Now I dont know if it is something that I am doing wrong as I have never had an av before and not really know what I am doing or weather it is a fault with the sub. I contacted the person I bought the sub from and he said
"have you set your reciver up properly ie, with a sub woofer as it will not send a signal to the sub if it has not been set up correctly, that is all i can think it is as the sub was working perfectly in my system"
could this be the case as I am still not to sure on how to set it up properly.
Any help would be appericated
