Hello!
I have recently upgraded my fronts and center speakers to PMC FB1's (originals not the +) and PMC DB1+C. The FB1's have a great open sound which i really like, but if you crank the volume up a bit the treble becomes a bit to bright (this doesnt really bother me with cinema but it does with music), this i know was a complaint of the FB1 speakers and there is the option to get them upgraded by PMC to the + version for around £600 which is one option!
The amp i have is a surround amp which won 5 stars a couple of years back in what hifi and was particually applauded for its musical ability it is the STR-DA2400ES into which i am running a Sonos system via an optical cable - FYI im testing the system with FLACS from a Synology NAS. I currently have some QED anniversary silver cable connecting the FB1's - but i have just bought some Russ Andrews 4TC cable as i hear copper wires give a more mellow sound.
So what are peoples advice as to how to balance out my system? As i see it i have a few options:
1) Upgrade FB1's to the FB1+ - My worry here is that it is really the amp that is too bright
2) Change the Amp - worry here is that most good surround amps would sound the same
3) Upgrade the cabling - does it really make THAT much difference?
4) Buy a power amp to handle the front left and right channels and use my current Sony as the pre amp
I'm leaning towards 4 - I used to have a Quad power amp that had a very mellow sound - unfortunatly back then i had dull speakers too! I've also heard that Naim kit goes very well with PMC speakers so perhaps a Naim power amp - With all of these i would probably be looking to ebay with around a £300 budget.
Any advice? ray:
Cheers Rob.
Any advice? ray:
Cheers Rob.
