Hello all,
I am looking to get a turntable to match this set up:
Monitor Audio Silver 8 tower speakers
Rogue Audio Sphinx integrated amp (which includes what I am told is a very good phono stage that can handle cartridges with output of 2.5mV or higher)
I have the above two components already. I am also willing to buy the Musical Fidelity V90-LPS phono stage if I need to go for a low-output moving-coil cartridge
Turntables I am considering:
Clearaudio Concept with Verify tonearm
Funk Firm Little Super Deck with F5 tonearm
Well Tempered Simplex with co.'s tonearm (not sure what it's called)
VPI Traveler with 10" tonearm
VPI Scout with 9" JMW tonenarm
SOTA Comet with S303 tonearm
I have only auditioned the Concept and the Little Super Deck at the moment, but hope to hear the others in the next couple of days. However, it is impossible for me to audition all of them side by side with the same speakers, amp, cartridge etc.
I did hear the Concept and LSD side by side but with different cartridges on each.
I loved the Concept's build quality -- it looks so good for its price. I heard it with the stock Clearaudio MM cartridge and while the music output was good, it wasn't great. Just seemed a bit too forward, bright and harsh to my ears (but only a bit)
The Little Super Deck is costlier, and I heard that with the Ortofon Quintet Bronze. The sound quality was noticeably better -- warmer, slightly laid back and overall smoother.
I am not sure if the difference was because of the cartridge more than the turntable itself. I reckon the Concept might sound just as good or even better with the same Ortofon Quintet Bronze. I don't know.
But in any case, the Little Super Deck's fit and finish weren't a patch on the Concept. Not terrible by any means, but a bit crude compared to the posh and smooth curves and lines of the Concept. The LSD just doesn't look like it will last a lifetime if so one desires, or maybe I am being shallow.
Here are my cartridge choices (which is proving to be very tough)
Clearaudio Maestro Wood - about S$1100-1400
Dynavector 10x5 (high output MC) - about S$500-600
Benz Micro Ace - about S$1200-1400
Van Den Hul DDT II Special - about S$1500-S$1800 (this is a low-output MC so I will have to buy the Musical Fidelity phono stage mentioned above)
Nagaoka MP-500
Nagaoka MP-300 (not sure of price but should be less than S$1000 I guess)
And finally (this one is going to raise some eyebrows because most may think it's overkill)...
Koetsu Rosewood Standard - about $1800-$2000 (again, I will have to get the phono stage for it). I am considering this only because I am getting a very good deal on it, and unlike in the U.S. where the price is substantially higher, there is no mark up in Asia for this brand
The problem for me is that I can't really listen to any of these cartridges because the opportunity for an audition doesn't exist where I stay. So I need your help in making a choice.
So please help.
Any suggestions/recommendations on the turntables mentioned above? Any ideas on which table might go best with which cartridge? For example, is pairing a competent table like the Concept with an entry-level Koetsu cartridge really a terrible idea?
I listen mostly to classic rock, alt-rock, blues and some pop. I seem to prefer a warmer sound with a liquid midrange rather than a bright and forward sound. I don't listen to music very loud and don't need thumping bass.
Keep in mind that my budget can't really beyond the costliest items listed above.
Any other recommendations?
Thank you.
Nagaoka MP-500
So please help.
Thank you.
