Heimdall
I use Heimdall speaker cable and its a significant step up from what I had before (Townshend Isolda). I expect the IC's share the same qualities although to have less effect the further away from the speakers you go.
It's too easy to analyse the sound quality (over the past year I've been the worst culprit), sometimes you have to sit back, a glass of red wine in your fist, and just ENJOY!
You could probably spend another 2k or so on upgrades and still not be totally satisfied.
plastic penguin:
I'm satisfied...but there is an inherent need to upgrade. Regularly. Nirvana will never be met.
