Headphones For £100-£200
Deleted member 2457
Marsbardark said:
Fair enough, I suppose looking nice is their most redeeming feature.
Yep, it did come in my decision making a little.
Deleted member 2457
I did try on this pair too:
http://www.whathifi.com/review/philips-fidelio-m1
But found the ear bits too big.
Ryanr1987
92
At your price point it's just full of different flavors. Two headphones stand out to my at this price and thats the Mrspeakers Mad Dog and Denon AH D600.
I think Sennheisers closed range are quite poor. The on ear momentum hasmore attack but that grainy sound was not nice. P5 are also rubbish IMO I really didn't get the hype for them at all. The P7 fixed their issues but sadly the price went even higher.
If you spend some time you can find some truly excellent headphones
A900x
K267
DT770
Mad Dog
SRH840
Deleted member 2457
A900x
K267
DT770
Mad Dog
SRH840
Ta bud, but just ordered the B&W P5's. :cheers:
Deleted member 2457
Do you have to run-in headphones, or just blast away?
Deleted member 2457
RodhasGibson said:
You'd be better just walking with them Gel or better still laying back on the sofa with a glass of something red.
:cheers:
I would like to hook them up to my home cinema system but the cable isn't long enough, any ideas where I could get one from? They are the B&W P5's.
:cheers:
RodhasGibson
191
9
18,595
gel said:
:cheers:
:cheers:
SubtotalQuantity
Closest store with stock:Milton Keynes (0.8m)
Stock at:Leighton Buzzard (9.3m)
021355_R_Z001
Homebase - Headphone Extension Cable - 5m
1£3.99Only 3 in stockFree Collection in store
Same day, next day, or a day of your choice.2 in stock
Home Base near you Gel. ;)
Deleted member 2457
RodhasGibson said:
gel said:
:cheers:
:cheers:
SubtotalQuantity
021355_R_Z001
That's fantastic! :cheers:
Deleted member 2457
Do you think this one will work too?
http://www.bowers-wilkins.co.uk/Shop/Recertified-Products-and-Accessories/Special-Deals/P7-5m-audio-cable.html
Deleted member 2457
The headphone cable won't go into my Pioneer amp, any ideas?
pauln
137
https://www.google.co.uk/shopping/product/17129501652386806699?q=3.5mm+jack+socket+to+twin+rca+cable&bav=on.2,or.r_qf.&biw=1350&bih=770&bvm=pv.xjs.s.en_US.Z62QQKvLNvM.O&tch=1&ech=1&psi=JIpiU87fHIKDOKezgeAJ.1398966954079.5&ei=x4piU4LSEMmkPciigZAH&ved=0CFUQpiswAA
Deleted member 2457
Is there an expensive option or are they all the same? :cheers:
Cheers for that!
pauln
137
You could probably find an audiophool example for £99 but you won't hear any difference. What you could try to get is a cable made up to the length you want with the correct plugs on each end. Saves having the original cable, an extension and an adaptor. I'm sure someone on ebay does such things.
RodhasGibson
191
9
18,595
gel said:
RodhasGibson said:
Why?
The hole on the amp is massive and the headphone cable is tiny.
You need one of these Gel.6.25mm male to 3.5mm female on Ebay for £1.68p
GOLD 3.5MM TO 6.35MM 1/4 JACK STEREO HEADPHONE ADAPTOR105 watching| [/b]1685 sold[/list]This adapter will convert a 3.5mm headphone-style input into 6.35mm 1/4 jack socket or 6.35mm MONO plug to a STEREO 3.5mm plug. Gold plated connections ensure a high quality connection.[/list]ConditionNew[/list]Time left13d 6h 12m[/list]PostageFree[/b][/list]Sold byraysoonuk2010 (217201 )99.4% Positive Feedback[/list]
Deleted member 2457
RodhasGibson said:
gel said:
RodhasGibson said:
Why?
Are cheers! Thanks for that. :).
Deleted member 2457
Cheers.
Deleted member 2457
gel said:
RodhasGibson said:
gel said:
RodhasGibson said:
Why?
This is definitely the one. Would my amp 170 watts output be too powerful for my headphones though?
