headphone amplifier
Rjpd77
6
Hi All
I have a Technics SL-1200MK2 & a Synthesis soprano tube amplfier. The soprano has no headphone out. I have a pair of Sennheiser HD599 which I use to listen to Maranntz CR610.
Question 1. Would the iFi Audio Zen CAN Headphone Amplifier be a good choice to allow me to listen to vinyl (Technics - soprano - iFi - headphones)? Any other suggestions? Elsewhere on this forum Jasonovich mentioned the XDUOO TA-66
Question 2. Would replacing my Sennheisers with the Grado SR325x be a good upgrade? Any other suggestions re upgrading the Sennheisers?
I suppose I'm just looking for assurance that all the components will complement each other and that there is no weak link or no component that is too 'good' for the rest
Thanks a mill
DougK1
563
803
1,270
Please excuse as I might be having a dim moment but your amp only appears to have inputs, no outputs. Where do you intend to get your feed from for the head amp?
Grado are marmite headphones, suggest you try before you buy.
Reactions: Gray and Al ears
Rjpd77
6
Hi All
Thanks a mill
it is me being dim. You are right. so the only way to listen to technics via headphone is to either replace the soprano or get the XDUOO TA-66 and switch the cables from the technics between the soprano & xduoo? Darn! thanks for comment Doug K1youre
DougK1
563
803
1,270
Don't be too hasty to ditch that lovely amp you have, there must be a way around this. Take a look at this thread: here He had the same issue, maybe the Douk Audio box he bought could be a way out, though I have no idea how it sounds. There must be others out there too.
To elaborate on Grado's, they have their own distinctive sound, very detailed, but I've always found them ruddy uncomfortable, especially so if you wear specs. Best to try before you buy but doubt you'll beat Sennheiser for comfort.
