nodnarb4444:so as we now no 1.3 hdmi works with 3d does that mean my old onk(705) will pass the 3d picture on to the tv
Nope, 1.3 spec HDMI does not work with 3D. You need 1.4 spec HDMI for 3D. This has been confirmed with people who have attempted to pass 3D from the PS3 to their TV through non 1.4 spec AV receivers - see
point 2 of the WHF blog.
The confusion is brought about by discussion of 1.3 and 1.4 cables - there is no such thing. A cable is either
High Speed certified in which case it is guaranteed to transport 1080p, 3D and ARC, or it's
Standard Speed certified, in which case it is guaranteed to pass 720p / 1080i material. It's further confused as many manufacturers over engineer their cables to ensure these guarantees are met, so although a cable is only
Standard Speed certified, it may well in fact pass 1080p and 3D over short distances as a result of this over engineering.
The terms 1.3 and 1.4 refer only to the HDMI ports themselves and the capabilities of the device which has them.
