Hi, I have a home set up that contains 5 TVs, 3 are 720p/1080i HD ready Stereo TV's, 2 are Full 1080p Dolby Digital/DTS TV's. I also have a Panasonic DMR-BS750 FreeSat HD/HDD/Bluray recorder.
I am currently using an 8 way HDMI Active Splitter/Amp to send the output of the Panasonic to each TV, picture is fine on all sets but drops to 1080i as expected because this is the lower resolution of the 5 TVs, however the audio output is also downmixed to PCM meaning that I can't get DD/DTS on the 2 TVs without having to disconnect the lower resolution TV's.
Is there a solution to my problem? Would an extra splitter/amp for 1080p & DD/DTS which then fed into a second splitter/amp for 1080i/Stereo solve it or would the lower resolution TVs still drag down the signal anyway?
MPW
MPW
