Half way there, kind of - so suggestions to match Monopulse As
CnoEvil said:
😛oke: Mr. Beard Does your new toy sound like an angel caressing your ears, or Beelzeub's horde assaulting your senses??
Well, that very much depends on what I am listening to!
I just haven't had time to give it much of a listen (moving house whilst trying to get builders finished and out) hence no report so far. Plugged everything in on Sunday just to check everything was working (it is!).
Rest assured, as soon as I get it all up and running I will let you know!
I never did receive my fair share of patience when it was being given out......that, and a sense of responsibility (guilt)....was starting to feel that no news was bad news!
Don't worry - I'm pretty good at screwing myself over without help from anyone else!
I couldn't comment at all on how it sounded yes - no warm up, on suspended floor, no spikes, no thought on speaker positioning blah blah blah - but did I mention it's very big?
CnoEvil said:
Big is GOOD! (Big and hot is better) >)
Mine weighs over 28 kg (for 35W !) and you could cook on it! :twisted:
OK, managed to get a bit of an extended listen today. Bunch of MP3s at 320 from iMac playing through iTunes (nothing extra like bitperfect etc) via optical out into Beresford Bushmaster to the A1001 powering the Monopulse via some unknown old cables I've had for yonks. Also tried CDs on Marantz 63 MkII KI Sig with and without the DAC, with cruddy old interconnect I've had for ages. All on the ground floor - a solid concrete floor - in a pretty massive room, I would say it's a good 8m by 10m (it's gonna be a kitchen/diner/party room once finished), with no plaster on walls, very high sloping ceiling in places, no furnishings whatsoever (it's an unfinished extension, I've got a lot of work to do!!!). Speakers a good 6m apart.
Crikey, that was a mouthful.
Anyways, VERY pleasing results - the amp takes some warming up, would say it didn't really hit its stride until about an hour in, at quite high volume. It didn't get too hot to start, but was heating up nicely all the way until I had to leave about 3 hours later. At which point it was really quite warm.
First things first, the Monopulse can go extremely loud. The A1001 can take them way up, without any distortion, beyond where either of my (admittedly much cheaper) amps could take them. I think "grip" is probably the word. I listened to mostly electronica such as Ellen Allien, Deadmau5 but also some stuff like Cat Power and Calexico - whatever I had available without much forethought.
MP3s via the Beresford sounded fantastic. CDP without Beresford sounded fantastic. But CDP with Beresford was utterly awesome. Just seemed to open everything up - vocals floating around, punchier bass, tight and stomach-whacking. Massive soundstage, everything great really. Disco like volume.
Listening position was anything from 2m in front of the speakers to about 7m back - optimal position was probably about 4m to 5m out.
Erm, not sure what's not to like. Just hope it doesn't change too much as I plaster/tile/put a kitchen in/add furnishings.
Yeah, like that's gonna make any difference!
Anyhows, very very happy right now - exactly the kind of noise I've been hoping/aiming for. And there will be improvements to be made no doubt - lossless files, speaker placement etc.
On the downside, the amp is so sodding huge and heavy that it's a total pain to lug around from one place to another. In fact the whole thing was a total ballache to set up - it needed extension leads and moving computers around etc on top of the weight of the amp. And have now had to pack everything back up and put away so builders don't destroy it all with dust and/or stupidity.
Darn.
I'm delighted that the first signs are hopeful.
I believe the goal was to replicate what you heard at your friend's house....and so now there's hopefully a good chance of that happening.
IMO. The sound you got for that initial trial, where you just plonked the thing down in a big unfinished space, would only be around 60% of what it will be capable of, when it's carefully set up in the finished surroundings (with decent cables etc).
Your system should have huge potential, and look forward to hearing about the finished article.
😛oke: Did you ever get the thing permanently set up?............and if so, are you still happy (with your fugly speakers :shifty: ) ?
Indeed, set up beautifully, sounds incredible every time. No thoughts of upgrading, but then my ears are pretty loose. Just bought a Denon Picollo with Dali Zensor 1 for the bedroom and have to say they sound incredibly good via airplay. Marantz 63 KI Sig or Airplay via Onkyo TX8050 through Mission 751 still sounding fantastic too. Those speakers are just the best value second hand ever. Beautiful things. Loving all my stuff at the mo, just coming up to getting the Pioneer A400 and Cerwin Vega VS10s into the garden.
Happy days dudes!!!!
