- Aug 10, 2019
- 2,556
- 5
- 0
Hi there, I posted a while back and I guess you were right - I didnt really know what I wanted but in the end went for the Denon Mini with Tannoy V1 Speakers and the Sony Blu Ray player - which is great except I dont have analogue outs that seem to work from the BT vision box (they dont support even through they are on there and there is a very slight delay on the feed) and the TV doesnt have any only digital outs!!!
So, the bottom line is that I need to sync the sound and picture. Picture is going through HDMI cable and Sound through the phono (2Channel) for Stereo.
Is there anything you can suggest to help here??? So how do I go from here. Only wanting the 2 channels (not 5.1) but wanting to be able to put a digital optical signal in I think OR is there another way I can do it? I have looked at DACs which are pretty expensive and I am hoping I dont really need to spend all that extra having just shelled out for all the above.
Assistance much appreciated. Thanks!!
PS Im hoping there is a simple solution!!
