JBL300MK2 SOUNDBAR
Tuanton
I am 90+ and would appreciate a bit of help please.
I am having difficulty in hearing clear dialogue in TV movies. I have LG Oled 55 TV, BT pro box and currently use a Samsung Q600C soundbar cconnected direct to the TV (not through
BT Box). Tried all recommended sound settings for Q600C but still not good enough for me, some links are OK but BBC iPlayer directr or via Netflix or Prime are really poor.
I have been recommended to look at JBL300MK2 for an improvement and reviews suggest this might be better. Not keen to spend more than the cost of the JBL (£345) - would welcome advice/recommendations please and thanks for looking.
Tks for the info. I will check TV settings. TV is
Firstly i would recommend you turn of all enhaced sound features on the TV first like AI if it has it and any others what LG TV is it ?
have a look at this £100 off and its LG so will work well with your TV
Tks for that info. Will check TV settings
TV is LG OLED 55C34LA .
your very welcome it does have AI acoustic tuning turn that off it also has AI sound pro turn that off .Turn on clear voice pro see if that works leave Dolby settings on .Good luck hope it helps 👍
