The_Lhc said:simonlewis said:https://www.flickr.com/photos/69466459@N04/9673088494/in/photostream/
That appears to be a birdfeeder.
Personally, given the above, I think it was £120 very wisely spent...
bigboss said:Looks very nice! Now you just need trunking for the cable sticking underneath the TV and paint it with the wall colour.
How's the TV?
simonlewis said:Apologies for that, i used to be able to copy and paste with the old site ...
The pictures have a hell of a lot of detail in them.chebby said:simonlewis said:Apologies for that, i used to be able to copy and paste with the old site ...
You still can ...
(Simon's photo.)
simonlewis said:my only complaint is that it is reflective when viewed from a certain angle, i wasn't expecting that i thought it would be the opposite.
gel said:Nice one Simon, looks great. What's your next purchase then, a 4K Blu-ray player?
bigboss said:simonlewis said:my only complaint is that it is reflective when viewed from a certain angle, i wasn't expecting that i thought it would be the opposite.
Why did you think the opposite. Concave surfaces attract all the light in. In the TV shootout review, I mentioned this:
"the reflection on the curved Samsung is far more distracting that the flat TVs."
Glacialpath said:PCM means nothing about the audio gets altered and is uncompressed, the DTS neo 2:5 is a fancy codec that can output for example a 5.1 audio stream to all the speakers on a set up if there are more than 6 = 5.1. This doesn't mean its a bad codec but it's not a true descrete audio codec as I think it pushes audio to the channels the 5.1 wouldn't be using.
Is this on your new TV (which looks very nice by the way) or a setting on an AV receiver?
simonlewis said:Glacialpath said:PCM means nothing about the audio gets altered and is uncompressed, the DTS neo 2:5 is a fancy codec that can output for example a 5.1 audio stream to all the speakers on a set up if there are more than 6 = 5.1. This doesn't mean its a bad codec but it's not a true descrete audio codec as I think it pushes audio to the channels the 5.1 wouldn't be using.
It's on the tv, i get a choice between PCM and DTS neo 2:5, i want what is natural and what ever is broadcast i presume that would be PCM, it is currently on DTS neo 2:5 at this moment so i will change it, their was a third one which was greyed out but i can't remember what it was.
